| | | Forums66 Topics128,181 Posts1,057,184 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2021 Posts: 42 'Bolter | | 'Bolter Joined: May 2021 Posts: 42 | Believe I got it fix. Made the adjustment holes that are slotted a little longer by elongating them at the top. This is where the "elbow" of the riser app rotates on a three-point mount. I enlarged the holes for the crank app and raised it slightly. When placing the window (framed) on its mounting track I pried it up while tightening the screws giving me a little more lift. But there is little one can do for the wear and tear of a 70-year-old mechanism, but I did peen the rivets on the joints tightening them a little.
Hopes this helps someone. Thanks
1950 Chevy 3100 PU all stock
