| | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | My take is either the goo or the adhesive is just there to hold the gasket in place till you install the pieces tighten the bolts. If it's a proper gasket it will seal without any goo. As far as which side goes up, strictly your choice, but I'd usually stick the gasket on the part that's facing up. A thermostat housing isn't something you'd normally try and reuse a gasket on, like a valve cover.
