2 members (60steve, 78buckshot), 75 guests, and 1 robot.
Topics128,212
Posts1,057,468
Members48,471
More questions for the peanut gallery:
The upper thermostat to lower thermostat housing gasket supplied by my FLAPS has a thin plastic peel off seal on one side. When you peel it off you find a thin adhesive on that side of the gasket.
Q: Which side goes up?
Q2: Should I trust the adhesive to seal with no additional goo? (My go to is Permatex #2)
Last edited by John Milliman; 07/01/2024 1:14 AM. Reason: Bill asked me to move this post and make it a stand alone question.
I've never done one on a Stovebolt but with others I've used, the peel and stick side is used to hold the T stat in place in the recess of the housing so it doesn't fall out during assembly.
Does the T stat sit in a recess in the housing?
If it sits in a recess on the engine, put the sticky side over the t stat and use a little rtv on the top side.
1950 Chevrolet 3100 (Ol' Roy)
My take is either the goo or the adhesive is just there to hold the gasket in place till you install the pieces tighten the bolts. If it's a proper gasket it will seal without any goo.
As far as which side goes up, strictly your choice, but I'd usually stick the gasket on the part that's facing up.
A thermostat housing isn't something you'd normally try and reuse a gasket on, like a valve cover.
