I'm glad your O.K. Otto & believe discharging your weapon will assure those dudes will not return. Waveski does have very a valid point, to each his own. Air tags (tracking devices) have been used to steal vehicles (& recover them) or even follow people home. Possible solution for recovery, there cheap & work. I need to get some.
Scary world out there.
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
