2 members (Nick in Manitou, 1 invisible),
60
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | No direct experience, but some people I've spoken with comment that it gives a somewhat lumpy idle, and low manifold vacuum at idle. "Valve open" duration (discounting clearance ramps at both ends of the lobe) of anything over the mid-260 degree level tend to kill low end torque and produce a choppy idle. That's true, no matter what engine we're discussing. The Elgin clone of the 261 cam (E-323S, I believe) lists a total duration of "300 degrees"- - - -but they include the total deviation from the base circle of the lobe, including clearance ramps on both ends, when the valve isn't actually open. The actual valve open time is in the high 250s or low 260s, IIRC. That's the cam we put into John's 261, and I degreed it during that engine buildup session. He's very pleased with it. Elgin isn't producing that cam at the moment, but I've got a brand new one that I'm planning to send to Schneider Cams so they can make a master cam from it. Then they can grind as many of them as they want as long as the have a good core to regrind- - - -solid or hydraulic cores don't make any difference- - - -the finished product will use solid lifters.
Boring a 261 to 3 7/8" would result in some paper thin cylinder walls, in my decidedly biased opinion! Jerry
Entire Thread
New engine project, a 261
| TUTS 59 | 04/04/2024 8:59 PM |
Re: New engine project, a 261
| BC59 | 04/04/2024 9:09 PM |
| JW51 | 04/04/2024 11:20 PM |
| TUTS 59 | 04/04/2024 11:28 PM |
| John Milliman | 04/05/2024 12:48 AM |
| TUTS 59 | 04/05/2024 1:15 AM |
| Otto Skorzeny | 04/05/2024 1:23 AM |
| TUTS 59 | 04/05/2024 1:30 AM |
| Hotrod Lincoln | 04/05/2024 2:11 AM |
| Bill Hanlon | 04/05/2024 2:32 AM |
| Hotrod Lincoln | 04/05/2024 2:43 AM |
| Phak1 | 04/05/2024 12:25 PM |
| TUTS 59 | 05/02/2024 5:05 PM |
| Hotrod Lincoln | 05/02/2024 8:07 PM |
| 52Carl | 05/03/2024 2:24 AM |
| TUTS 59 | 05/03/2024 11:45 AM |
| Dragsix | 05/03/2024 2:06 PM |
| VEW | 05/06/2024 7:54 PM |
| Hotrod Lincoln | 05/07/2024 6:07 PM |
| Dragsix | 05/07/2024 6:15 PM |
| TUTS 59 | 05/07/2024 6:49 PM |
| Hotrod Lincoln | 05/07/2024 6:55 PM |
| Tronman | 05/07/2024 8:51 PM |
| Hotrod Lincoln | 05/08/2024 4:40 AM |
| TUTS 59 | 05/08/2024 1:17 PM |
| TUTS 59 | 05/08/2024 4:42 PM |
| TUTS 59 | 05/10/2024 3:34 PM |
| Hotrod Lincoln | 05/10/2024 3:45 PM |
| Hotrod Lincoln | 05/10/2024 4:07 PM |
| Dragsix | 05/10/2024 9:50 PM |
| JW51 | 05/10/2024 10:52 PM |
| Hotrod Lincoln | 05/11/2024 12:04 AM |
| Dragsix | 05/11/2024 3:59 AM |
| TUTS 59 | 05/11/2024 12:13 PM |
| 1Ton_tommy | 05/12/2024 10:47 PM |
| panel fan | 05/13/2024 12:54 PM |
| JW51 | 05/13/2024 1:35 PM |
| 1Ton_tommy | 05/13/2024 9:30 PM |
| Gdads51 | 05/13/2024 1:47 PM |
| JW51 | 05/13/2024 2:01 PM |
| TUTS 59 | 05/13/2024 9:56 PM | |
