1 members (Hotrod Lincoln),
95
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,677 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 3,380 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,380 | This engine build will be nothing exotic, no custom pistons, no one off valve train. The main idea is to go oversized .110" to add a few cubic inches (276 CID), deck the block around.010 and mill the head .030" - .060" to add some compression. Pistons can be sourced, JE and Ross still have them in production. The cam as many of you have pointed out will be on the "smaller" side with around 210° to 212° Intake and 218° to 220° exhaust duration at .050" lift. I may go smaller as this is a Torque engine, something in the 190/220 duration @ .050 range. The intake and exhaust will most likely remain stock.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | |
Entire Thread
New engine project, a 261
| TUTS 59 | 04/04/2024 8:59 PM |
Re: New engine project, a 261
| BC59 | 04/04/2024 9:09 PM |
| JW51 | 04/04/2024 11:20 PM |
| TUTS 59 | 04/04/2024 11:28 PM |
| John Milliman | 04/05/2024 12:48 AM |
| TUTS 59 | 04/05/2024 1:15 AM |
| Otto Skorzeny | 04/05/2024 1:23 AM |
| TUTS 59 | 04/05/2024 1:30 AM |
| Hotrod Lincoln | 04/05/2024 2:11 AM |
| Bill Hanlon | 04/05/2024 2:32 AM |
| Hotrod Lincoln | 04/05/2024 2:43 AM |
| Phak1 | 04/05/2024 12:25 PM |
| TUTS 59 | 05/02/2024 5:05 PM |
| Hotrod Lincoln | 05/02/2024 8:07 PM |
| 52Carl | 05/03/2024 2:24 AM |
| TUTS 59 | 05/03/2024 11:45 AM |
| Dragsix | 05/03/2024 2:06 PM |
| VEW | 05/06/2024 7:54 PM |
| Hotrod Lincoln | 05/07/2024 6:07 PM |
| Dragsix | 05/07/2024 6:15 PM |
| TUTS 59 | 05/07/2024 6:49 PM |
| Hotrod Lincoln | 05/07/2024 6:55 PM |
| Tronman | 05/07/2024 8:51 PM |
| Hotrod Lincoln | 05/08/2024 4:40 AM |
| TUTS 59 | 05/08/2024 1:17 PM |
| TUTS 59 | 05/08/2024 4:42 PM |
| TUTS 59 | 05/10/2024 3:34 PM |
| Hotrod Lincoln | 05/10/2024 3:45 PM |
| Hotrod Lincoln | 05/10/2024 4:07 PM |
| Dragsix | 05/10/2024 9:50 PM |
| JW51 | 05/10/2024 10:52 PM |
| Hotrod Lincoln | 05/11/2024 12:04 AM |
| Dragsix | 05/11/2024 3:59 AM |
| TUTS 59 | 05/11/2024 12:13 PM |
| 1Ton_tommy | 05/12/2024 10:47 PM |
| panel fan | 05/13/2024 12:54 PM |
| JW51 | 05/13/2024 1:35 PM |
| 1Ton_tommy | 05/13/2024 9:30 PM |
| Gdads51 | 05/13/2024 1:47 PM |
| JW51 | 05/13/2024 2:01 PM |
| TUTS 59 | 05/13/2024 9:56 PM | |
