2 members (walter74, 1 invisible),
102
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | If one shaves too much off of one of these heads, You remove the "quench trench". With not enough room for the air to flow when the Big Bang takes place, much heat is created which will turn what is left of the quench trench gun metal, case hardened blue and cooks the intake valves. I must say that the added compression from doing this results in a remarkable increase in performance, but at the cost of a perfectly good head in short order. I have heard of angle milling a head, favoring metal removal on the exhaust side of the head. This preserves the quench trench, while increasing compression ratio. Then you will only have to worry about throwing a rod which likes to break where the clamp bolt for the wrist pin is when the engine gets pushed too hard.
Entire Thread
New engine project, a 261
| TUTS 59 | 04/04/2024 8:59 PM |
Re: New engine project, a 261
| BC59 | 04/04/2024 9:09 PM |
| JW51 | 04/04/2024 11:20 PM |
| TUTS 59 | 04/04/2024 11:28 PM |
| John Milliman | 04/05/2024 12:48 AM |
| TUTS 59 | 04/05/2024 1:15 AM |
| Otto Skorzeny | 04/05/2024 1:23 AM |
| TUTS 59 | 04/05/2024 1:30 AM |
| Hotrod Lincoln | 04/05/2024 2:11 AM |
| Bill Hanlon | 04/05/2024 2:32 AM |
| Hotrod Lincoln | 04/05/2024 2:43 AM |
| Phak1 | 04/05/2024 12:25 PM |
| TUTS 59 | 05/02/2024 5:05 PM |
| Hotrod Lincoln | 05/02/2024 8:07 PM |
| 52Carl | 05/03/2024 2:24 AM |
| TUTS 59 | 05/03/2024 11:45 AM |
| Dragsix | 05/03/2024 2:06 PM |
| VEW | 05/06/2024 7:54 PM |
| Hotrod Lincoln | 05/07/2024 6:07 PM |
| Dragsix | 05/07/2024 6:15 PM |
| TUTS 59 | 05/07/2024 6:49 PM |
| Hotrod Lincoln | 05/07/2024 6:55 PM |
| Tronman | 05/07/2024 8:51 PM |
| Hotrod Lincoln | 05/08/2024 4:40 AM |
| TUTS 59 | 05/08/2024 1:17 PM |
| TUTS 59 | 05/08/2024 4:42 PM |
| TUTS 59 | 05/10/2024 3:34 PM |
| Hotrod Lincoln | 05/10/2024 3:45 PM |
| Hotrod Lincoln | 05/10/2024 4:07 PM |
| Dragsix | 05/10/2024 9:50 PM |
| JW51 | 05/10/2024 10:52 PM |
| Hotrod Lincoln | 05/11/2024 12:04 AM |
| Dragsix | 05/11/2024 3:59 AM |
| TUTS 59 | 05/11/2024 12:13 PM |
| 1Ton_tommy | 05/12/2024 10:47 PM |
| panel fan | 05/13/2024 12:54 PM |
| JW51 | 05/13/2024 1:35 PM |
| 1Ton_tommy | 05/13/2024 9:30 PM |
| Gdads51 | 05/13/2024 1:47 PM |
| JW51 | 05/13/2024 2:01 PM |
| TUTS 59 | 05/13/2024 9:56 PM | |
