7 members (Gray_Ghost, JW51, kades51, Wally / Montana, Bill Hanlon, warlock, 1 invisible),
70
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,724 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Be careful about "unshrouding" the intake valves- - - -unless you enjoy changing valves every few months. The intake valve is recessed into the cylinder head for a good reason- - - -to shield the edge of it from the flame front as the cylinder fires. I've got a very nice 848 head that was given to me after a couple of milling jobs- - - -because it burned up intake valves frequently. I can fix it, but the machinist who did the milling had his head firmly inserted into a dark, stinky place! Use the 1.94" intakes for a Powerglide-equipped 235 spray oiler engine and pocket port the tulip area of the port above the valve, but be sure to keep the protective lip in place that deflects the flame front away from the edge of the valve. Jerry
Entire Thread
New engine project, a 261
| TUTS 59 | 04/04/2024 8:59 PM |
Re: New engine project, a 261
| BC59 | 04/04/2024 9:09 PM |
| JW51 | 04/04/2024 11:20 PM |
| TUTS 59 | 04/04/2024 11:28 PM |
| John Milliman | 04/05/2024 12:48 AM |
| TUTS 59 | 04/05/2024 1:15 AM |
| Otto Skorzeny | 04/05/2024 1:23 AM |
| TUTS 59 | 04/05/2024 1:30 AM |
| Hotrod Lincoln | 04/05/2024 2:11 AM |
| Bill Hanlon | 04/05/2024 2:32 AM |
| Hotrod Lincoln | 04/05/2024 2:43 AM |
| Phak1 | 04/05/2024 12:25 PM |
| TUTS 59 | 05/02/2024 5:05 PM |
| Hotrod Lincoln | 05/02/2024 8:07 PM |
| 52Carl | 05/03/2024 2:24 AM |
| TUTS 59 | 05/03/2024 11:45 AM |
| Dragsix | 05/03/2024 2:06 PM |
| VEW | 05/06/2024 7:54 PM |
| Hotrod Lincoln | 05/07/2024 6:07 PM |
| Dragsix | 05/07/2024 6:15 PM |
| TUTS 59 | 05/07/2024 6:49 PM |
| Hotrod Lincoln | 05/07/2024 6:55 PM |
| Tronman | 05/07/2024 8:51 PM |
| Hotrod Lincoln | 05/08/2024 4:40 AM |
| TUTS 59 | 05/08/2024 1:17 PM |
| TUTS 59 | 05/08/2024 4:42 PM |
| TUTS 59 | 05/10/2024 3:34 PM |
| Hotrod Lincoln | 05/10/2024 3:45 PM |
| Hotrod Lincoln | 05/10/2024 4:07 PM |
| Dragsix | 05/10/2024 9:50 PM |
| JW51 | 05/10/2024 10:52 PM |
| Hotrod Lincoln | 05/11/2024 12:04 AM |
| Dragsix | 05/11/2024 3:59 AM |
| TUTS 59 | 05/11/2024 12:13 PM |
| 1Ton_tommy | 05/12/2024 10:47 PM |
| panel fan | 05/13/2024 12:54 PM |
| JW51 | 05/13/2024 1:35 PM |
| 1Ton_tommy | 05/13/2024 9:30 PM |
| Gdads51 | 05/13/2024 1:47 PM |
| JW51 | 05/13/2024 2:01 PM |
| TUTS 59 | 05/13/2024 9:56 PM | |
