As long as you don't have a bunch of loose rod bearings and/or low oil pressure, your 235 will live happily ever after at any RPM below 3K, and it won't self destruct at 3200 for short spurts. Most of the engine noise people obsess about with an old stovebolt when it's wound up is coming from the fan. Just for grins, pull the fan blade off and make a highway run. You'll be amazed at how much less noise you hear, at road speeds you wouldn't even think about running otherwise.
