I finally got around to tackling this project. I have never done anything remotely like this so it took some time to psych myself up to start on it. The front of the rocker was pretty bad so I replaced that. When I mock up the inner brace and outer cowl it's not quite lined up with the holes for the parking brake. Everything is just tacked on so far. I guess I'll redo the patch on the rocker? The only other thing I an think of it to cut the holes out to match.
