You referenced armature may be stuck in the coil - could you expand on that , help me understand how the horn is supposed to function?
I understand the internal combustion engine with its pistons, crankshaft, camshaft and valves ; I should be able to understand the horn with a bit of a nudge.
I.E. : what are those points supposed to do?
