Back in the day, replacement points used to come with a tiny capsule of grease that was supposed to be used to lubricate the rubbing block on the points where it contacts the cam. A little bit of grease there can't hurt.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
