| | | Forums66 Topics128,109 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | The spare on my F250 is held in place only by the cable winch. It's been up there for nearly 25 years without a problem. So the threaded rod you're talking about would just be another thing to fiddle with if you need to take the spare out. I think that the winch would work just fine without the extra threaded rod. You'd just need to mount the winch so that you could raise the wheel enough to tuck it into the pocket and then crank it up to land behind the side rail of the bed.
