Originally Posted by latroca52
I have a 53 Chevy truck with a 235
I want to install a toggle switch to bypass the temperature sensor to turn on as needed I was told I need to install a diode between the fan and the temp sensor so not to send a reverse current to the sensor or relay.
Thanks
No diode needed. e.g.
https://enginedburner.z19.web.core.windows.net/electric-fan-relay-wiring-schematic.html
Gord 🇨🇦
1954 1/2 ton 235 4 speed
