| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Adjust the pedal linkage so the MC returns completely to its fully released position when you're off the brake pedal. There is a relief port at the extreme rearward point of the MC piston travel which must be uncovered to allow pressure to release in the brake lines. Jerry
