| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | We ran a big flat washer instead of a thermostat on the race engines and varied the size of the hole in it to control the temp we wanted the engine to run. If the radiator is efficient enough it will over-cool without some type of flow restrictor. I can look at the wear pattern on the piston skirts of a high mileage street engine and tell whether or not it has been run with a thermostat installed. Jerry
