| | | Forums66 Topics128,136 Posts1,056,431 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,818 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | I've used a piece of steel cable in a drill motor to clear the crud out of a petcock drain port, but that's only the beginning. Once the coolant will drain, you'll need to circulate a very aggressive cleaner like phosphoric acid or Trisodium Phosphate (one at a time, not together) to clean the crud out of the bottom of the block. The acid dissolves rust and other metallic contaminants. The TSP cuts greasy deposits. Both chemicals are available on Ebay and they can be mixed in much stronger concentrations than are available in commercial flush products. It will be a long, tedious process to get the block really clean. Jerry
Entire Thread
Perferred water coolant cleaner, 235 engine.
| Ol'55 | 02/05/2024 2:04 PM |
Re: Perferred water coolant cleaner, 235 engine.
| Norcal Dave | 02/05/2024 2:22 PM |
| Otto Skorzeny | 02/05/2024 3:16 PM |
| Ol'55 | 02/05/2024 3:59 PM |
| Hotrod Lincoln | 02/07/2024 4:56 AM |
| Daves46pu | 02/07/2024 6:13 PM |
| Ol'55 | 02/13/2024 2:32 PM |
| Jon G | 02/13/2024 3:09 PM |
| JW51 | 02/13/2024 6:33 PM |
| Jethro in Va | 02/13/2024 9:59 PM |
| Ol'55 | 02/15/2024 4:16 AM |
| Jethro in Va | 02/15/2024 9:51 AM |
| Otto Skorzeny | 02/15/2024 12:49 PM |
| Phak1 | 02/15/2024 1:43 PM |
| Hotrod Lincoln | 02/15/2024 2:25 PM |
| JW51 | 02/15/2024 3:49 PM |
| Shaffer's1950 | 02/15/2024 5:57 PM | |
