I am using a dual remote oil filter kit from Jegs. It is made by Perma Cool??? and uses the ford style filters. I used 5/8 line and push on fittings from NAPA. In hindsight, it would have been cheaper to get the complete kit including lines; however those lines are 1/2 inch diameter. I have s single spin on filter (bypass) on my 302 without the restrictor orifice; the lines are small enough that I only loat two or three psi of oil pressure. If you only plan to use the bypass filter, I would check into the designed-for bypass filters. Maybe they aready have the built in restriction.
Jason
