7 members (Lightholder's Dad, Otto Skorzeny, KEVINSKI, lumbersawyer, BC59, tclederman, 1 invisible),
67
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | We replace a couple wheel cylinders and rebuilt the master cylinder. When we took the truck out the brakes built up and started smoking. We opened the bleed screw o a couple wheels and it squirted fluid out. the brakes were okay for a few miles and started smoking again. Had to bleed a little fluid again. How full do I leave the master cylinder? Is there something else I need to look at? 3 of four wheels were very hot. Thanks for suggestions.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
