GM Parts WiKi shows part #3701322 as a 1/4” rubber shim which is located below the frame mount, as well as part #3701323 which I assume is the square washer. I also assume part #3685418, located between the frame mount and the cab, is the shims used to adjust the frame to cab clearance. So what is part #3806863 and what is is made of? Couldn’t find it in GM Parts WiKi.
Front Cab Mount Exploded
Phil
Project Journals
Stovebolt Gallery Forum
