| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | I also use a hole saw to cut the tops out of pistons that are rusted into the bore. Leaving a ring of piston material just a little inside of the piston ring inside dimension and smacking the center with a BFH frees up a crankshaft pretty well without damaging the crankshaft or connecting rods. Jerry
