| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Unless you're planning to do real truck stuff with an antique vehicle, I don't see a problem with using the smaller clutch. There are plenty of good condition used 235/261 flywheels available that can have the clutch contact surface reground- - - -no point in throwing away good money on a brand new one. Just be sure to get one with the 139 tooth 6 volt ring gear. I'd machine a spacer ring for the center hole if I was doing the swap- - - -just a few minutes' work on the lathe and a piece of pipe nipple. Jerry
