Originally Posted by Waveski
I did read the tech tip. I thought it held the key to solving my problem, which is:
The lower trailing edges (sides) of the hood were hugging the truck, while the upper edge was high in relationship to the cowl , all across the hood.
I loosened the center bridge piece and added washers/shims between the outboard ends and the frame members as instructed. The result was , center of hood came down while the mid point flanks were still quite high. The sides no longer hugged the cab. I then loosened that centerpiece again, reducing washers from 4 to 3. Slight improvement , but still not a good fit relative to the cowl.
I will make another incremental adjustment in my next garage session, but my hope of getting a good fit is not strong.
I am working with the original cab , and a 1954 hood that is not original to the truck. Did Chevrolet fit hoods individually back then? Do hoods vary from truck to truck?
Waveski - the hoods for the 1954-55 1st Series Truck are different than the 1947-53 Hoods. The left/right hood section part numbers for the 47-53 are 3682615 / 2616. The 54-55 1st are 3701466 / 1467. I cannot tell you what the difference is but I seem to recall Denny Graham discussing this issue at one point. I've attached two photos that Denny had in his database. I'm fairly certain he won't mind if I share them with you.
Ron - - Dusty53
1954 Chevy 3604
In the Gallery Forum
