Like this:
https://www.amazon.com/Clamp-On-Leaf-Spring-Mount-Pad/dp/B01N9VQ6BQ
Makes the work of setting, adjusting, re-adjusting, etc a lot easier. And as far as welding you can just weld the southern hemisphere of the mount if you think you might want to adjust your pinion angle later. That gives you plenty of strength.
~ Jon
