| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 149 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 149 | Just to make sure you got the correct filter in the box...here's the diametrical info on the correct filters for the 235/261 engines... the would apply as long as you still have the original filter can.... If it was changed/swapped at some time...then it'll be a trial and error as to what filter you need...... but you can also look as most all canister style filters are stamped with their number...
The diametrical difference between the Fram C21(P) and the C4 filters is as follows; Outside diameter C4- 4 5/16 and C21P- 4.5 inches Inside diameter C4 and C21P both 9/16 Height C4- 4 13/16 and C21P- 5 inchs Gasket number(Fram) C4 151915 C21P 125405 Gasket dimetions Outside diameter C4 4.75 and C21P 5.128 Inside diamter C4 4 11/32 and C21P 4 3/8 Thickness C4 1/16th and C21P 3/32nd
The Fram C21(P) interchanges with the AC115 and WIX 51100 and NAPA 1100 filters The FRAM C4 interchanges with the WIX 51006 and NAPA 1006 filters
Hope this helps Michael \'48 chev 2-ton boom truck (Boomer) '49 Chev 2-ton flat bed '65 Chev 35ft school bus '88 GMC 6500 '72 Superior 26ft class "A" coach '50 Farmall "M" '71 MGB GT '68 Austin-Healey Sprite '65 Austin-Healey Sprite and various other odd British cars and lots of old radios..... Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
