0 members (),
61
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,037 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,037 | Those screws are #10 flat head sheet metal screws. I believe the originals were likely clutch head, but you can find phillips head at any hardware. Probably 1/2" long is plenty long enough. I confirmed the diameter in the channel from my pile of parts not installed yet. I probably have the original screws in a bag, but they're buried deeper than the channel was.
