good morning,
the last time i removed a trans from my 38 was about 15 years ago. i have to take my trans to the shop, it wont go into 1st and 3rd. they will check it out, but i need to remove it
car is jacked up on all four with jacks
i split the yoke
removed e brake assembly to allow it to drop and speedo cable
removed bolts that hold trans to cross member
took off 4 bolts from trans to bell housing
per the manual there are two top trans to clutch housing screws and two lower ones, it was getting dark and we stop due to my bad eyes, doensy anyone have a pic of these two where they are located?
thanks in advance!
