I could not get the grommet into the sheetmetal with the hinge in place, the gap is too tight. I looked at another hinge and saw the pin is pressed in tight, so decided to not go that route. I ended up removing the hinges from the truck, installing on the doors. With grommets in place on the truck and some soapy liquid was able to work the hinged doors into place. The results are acceptable. I started one corner of a hinge in the opposite end of the grommet and slid it down into place so the whole end of the hinge cleared the grommet. As I pushed the hinge in, the grommet tended to curl in. I could push the hinge in some, the grommet would curl in, and then pull the hinge out less than I had pushed it in to get the grommet out again. It was hard to get a grip on the grommet with the soap on it. I started the top hinge, then started the bottom hinge, then worked each one into place.
