| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | The difference is in the diameter of the flywheel/flex plate. I don't recall which is which, but offsetting the starter drive gear aligns it with the different flywheel diameter. The dimension change isn't much, but it's important to match the starter with the flywheel. Jerry
