Winter is Coming
Where the starter mounts on the block there are 3 bolt holes. The outer hole is used on both starters. The inner holes are for either a straight mount, or an offset mount.
1962 C10 with a 235 6cyl -- all of the drive train seems to be original. Some of this story is in the Side Lot Some people like a new truck. I liked the old ones.
