Whereabouts exactly was the serial number on the rail? The frame has been cut at the very front and had a 1/2 plate welded on it where the engine mounts. I couldn't find any numbers on it. No numbers on rear diff either. I have a picture of a number on the back face of the 4spd Trans, not sure if it is a serial number or just a part number. Engine block is currently at shop right now.
