Thinking since I am just going to get the truck rolling before doing a huge off frame project.
First thing I want to do is to replace the window and door seals to keep out the weather while it's stored outside.
From what I see is the door to cab seal is glued on, I'd hate to remove and replace the seals and not do anything about any rust under the seal. I don't want to start sanding and painting messing up the original paint, even tough a full paint job in the future in the plan.
Was told to use POR-15, also told that stuff is hard to remove once on there.
Is there any other alternatives or best way to tackle this project? Website Links? Videos?
Are there any seals that can push on instead of gluing? Like ones with a groove to push onto the cab edge?
Would like to replace the windshield and rear window seals, if not leaking, they can wait.
The goal is to make the truck drivable and keep dry inside while I am working on it till I am fully ready to tackle the frame-off restore. At least I can get a feel of what I really want to do with the truck.
1954 GMC 150-24 Truck
The Stovebolt Collective Weighs In
