0 members (),
132
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,276 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | If you work the truck and use a vented oil-filler cap, bear in mind that at 0 vacuum there will be fumes coming out of the filler cap. On my truck I can smell it and that reminds me to ease up a bit and hold about 2" vacuum. That eliminates the problem and probably forestalls others arising from running WOT for extended time. Sometimes I drop a gear netting about +400RPM and a bit better vacuum; maybe even better fuel consumption. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
