0 members (),
132
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,276 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,933 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,933 | Ignore the advice about using a freeze plug in the road draft tube hole unless you own a lot of stock in an oil company. The factory original PCV valve was in a standpipe at approximately the height of the lip of the valve cover to prevent splashed oil from being drawn into the valve and burned by the engine. Use an oil filler cap with a vent to admit fresh air into the engine for ventilation if you choose not to use the factory method of plumbing air from the "clean" side of the air filter into the rear of the valve cover near the back of the driver's side. That system was used on delivery trucks, step vans like bread trucks, and others which seldom got up to 30 MPH where the road draft starts to work properly. Jerry
