Gord, there are only two different TO bearings, and the other one has a curved surface for three finger clutches…mine is a diaphragm clutch, so I think I’m stuck with the TO bearing that I have…which has the flat surface.
If I use the longer TO bearing, then I will have to change to a three finger style clutch cover (which may be the only choice I have left if there is no adjustable pivot ball that will work with this cast clutch fork.
[Edit] i just discovered the McLeod adjustable GM throw out bearing. Adjusts from 1 3/8 to 1 13/16. It has a flat surface for diaphragm clutches. I have ordered it and this should get me close enough- it can be adjusted to three different lengths… I’ll
report back here once it’s installed.
~ Dave
1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission
