| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | There's a temporary fix- - - -install a Melling M-29 oil pump that's intended to fit a 1953-54 235 engine. It has bigger gears and slightly more volume than a 216 pump, and it's sort of a band-aid fix to compensate for worn bearings. It requires a little bit of creative plumbing of the pump pickup and pressure lines to make it fit. Jerry
