1 members (Hotrod Lincoln),
61
2
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Per the Owners Manual you ALWAYS park in Low Range. This prevent gravity from pulling the vacuum actuator out of Hi Range while it's parked allowing the rear to fall between gears and letting it roll away... Mike B  | | |
