| | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | I have a 1954 3604 with the original 235 engine that has had the intake and exhaust manifold swapped to the 216 manifolds. I read in another post that a 216 carb on a 235 would run too rich ( fuel mixture ). A 216 carb will not install on a 235 intake manifold so the discussion must mean that someone else has a similar situation. Can someone clarify the "rich" mixture issue and advise if there are any solutions other than getting the correct intake/exhaust manifolds and correct Rochester B ( yeah I know, get a Carter YF2100 ) . This issue is aggravating since I have a very nice functioning intake /exhaust manifold and carb....but the exhaust pipe is sooty black so I'm thinking its running rich. Ok, open the floodgates of knowledge and experience and give it to me straight!
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | |
Entire Thread
216 Intake / Exhaust Manifolds on a 235, help?
| Dusty53 | 03/16/2023 12:20 AM |
Re: 216 Intake / Exhaust Manifolds on a 235, help?
| JW51 | 03/16/2023 12:24 AM |
| JW51 | 03/16/2023 12:27 AM |
| Otto Skorzeny | 03/16/2023 12:29 AM |
| panic | 03/16/2023 1:40 PM |
| Skooter | 03/16/2023 12:35 AM |
| JW51 | 03/16/2023 11:06 AM |
| Hotrod Lincoln | 03/16/2023 2:24 PM |
| JW51 | 03/16/2023 2:41 PM |
| 52Carl | 03/17/2023 1:29 AM |
| Dusty53 | 03/16/2023 4:11 PM |
| Otto Skorzeny | 03/16/2023 7:00 PM |
| panic | 03/16/2023 10:17 PM |
| Dusty53 | 03/16/2023 10:28 PM |
| Hotrod Lincoln | 03/16/2023 4:26 PM |
| JW51 | 03/16/2023 4:38 PM |
| JW51 | 03/17/2023 3:19 AM |
| fixite7 | 03/17/2023 2:13 PM |
| Dusty53 | 03/17/2023 4:49 PM |
| fixite7 | 03/17/2023 9:37 PM |
| Dusty53 | 03/17/2023 4:44 PM |
| Hotrod Lincoln | 03/17/2023 5:40 PM |
| Hotrod Lincoln | 03/17/2023 6:18 PM |
| Dusty53 | 03/17/2023 9:34 PM |
| Dusty53 | 03/17/2023 10:54 PM |
| 1Ton_tommy | 03/19/2023 8:19 PM |
| Dusty53 | 03/19/2023 9:47 PM | |
