| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | In my teens I worked in a welding shop, ca 1965. The shop owner was a master welder having done that in the military and for a heavy construction company before he went on his own. One day someone brought in a 392 Chrysler Hemi engine cracked from freezing. I recall that he drilled a series of holes along the crack that went the whole length of the block. He used cast iron rod and welded from hole to hole, much like one does with sheet metal. In the end it was ugly but didn't leak when back in the car. I think it came out of a 58 Imperial so it was still worth some money at the time. Not saying that's what you should do but I saw it done many years ago. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | |
Entire Thread
45 Chev, 53 Chev cracked block
| blewis9991 | 03/11/2023 8:39 PM |
Re: 45 Chev, 53 Chev cracked block
| klhansen | 03/11/2023 8:53 PM |
| blewis9991 | 03/12/2023 12:08 AM |
| blewis9991 | 03/12/2023 12:13 AM |
| blewis9991 | 03/13/2023 5:38 AM |
| fixite7 | 03/14/2023 11:52 AM |
| blewis9991 | 03/27/2023 5:52 PM |
| fixite7 | 03/25/2023 11:08 AM |
| Otto Skorzeny | 03/11/2023 10:59 PM |
| klhansen | 03/12/2023 12:17 AM |
| Otto Skorzeny | 03/12/2023 12:20 AM |
| 52Carl | 03/12/2023 2:00 AM |
| Otto Skorzeny | 03/12/2023 3:14 AM |
| 52Carl | 03/12/2023 6:28 PM |
| NorthCoast3800 | 03/12/2023 4:12 AM |
| Hotrod Lincoln | 03/12/2023 5:43 AM |
| texczech | 03/18/2023 12:07 PM |
| fixite7 | 03/12/2023 11:58 AM |
| klhansen | 03/12/2023 7:01 PM |
| 2ManyTrucks | 03/13/2023 2:10 AM |
| 1Ton_tommy | 03/13/2023 3:55 AM |
| texczech | 03/18/2023 12:08 PM |
| Hotrod Lincoln | 03/18/2023 2:20 PM |
| Phak1 | 03/19/2023 1:38 PM |
| blewis9991 | 03/27/2023 5:58 PM |
| jay d | 03/20/2023 12:31 AM |
| JiMerit Boltr#43 | 03/23/2023 5:33 PM |
| Otto Skorzeny | 03/23/2023 5:35 PM | |
