1 members (VicZ),
231
2
Mod | | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | 216's are readily available, but not new. You might be able to buy a runner from another Stovebolter. Suggest you post an ad in the Truck Parts Wanted forum. Maybe someone is doing an engine swap and has one that you could use. Worst case, you'd need to rebuild it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | |
Entire Thread
45 Chev, 53 Chev cracked block
| blewis9991 | 03/11/2023 8:39 PM |
Re: 45 Chev, 53 Chev cracked block
| klhansen | 03/11/2023 8:53 PM |
| blewis9991 | 03/12/2023 12:08 AM |
| blewis9991 | 03/12/2023 12:13 AM |
| blewis9991 | 03/13/2023 5:38 AM |
| fixite7 | 03/14/2023 11:52 AM |
| blewis9991 | 03/27/2023 5:52 PM |
| fixite7 | 03/25/2023 11:08 AM |
| Otto Skorzeny | 03/11/2023 10:59 PM |
| klhansen | 03/12/2023 12:17 AM |
| Otto Skorzeny | 03/12/2023 12:20 AM |
| 52Carl | 03/12/2023 2:00 AM |
| Otto Skorzeny | 03/12/2023 3:14 AM |
| 52Carl | 03/12/2023 6:28 PM |
| NorthCoast3800 | 03/12/2023 4:12 AM |
| Hotrod Lincoln | 03/12/2023 5:43 AM |
| texczech | 03/18/2023 12:07 PM |
| fixite7 | 03/12/2023 11:58 AM |
| klhansen | 03/12/2023 7:01 PM |
| 2ManyTrucks | 03/13/2023 2:10 AM |
| 1Ton_tommy | 03/13/2023 3:55 AM |
| texczech | 03/18/2023 12:08 PM |
| Hotrod Lincoln | 03/18/2023 2:20 PM |
| Phak1 | 03/19/2023 1:38 PM |
| blewis9991 | 03/27/2023 5:58 PM |
| jay d | 03/20/2023 12:31 AM |
| JiMerit Boltr#43 | 03/23/2023 5:33 PM |
| Otto Skorzeny | 03/23/2023 5:35 PM | |
