| | | Forums66 Topics128,108 Posts1,056,228 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I see no problem with kingpin front ends and speed. Every big rig I know of has a kingpin front end and most can go plenty fast.
The only concern is that they are not worn out. As for brakes, the old brakes on our trucks should be fine at moderate speeds if they are in good condition and you are unloaded. As you approach a full load I would try to stay under the max speed the truck would go originally, about 45 or so for a 2 ton. Experience will tell if they are good enough for speeds faster and with more weight. If you want to go fast all the time I would at least upgrade to a dual circuit brake system / master cylinder. | | |
