Originally Posted by Wrenchbender Ret.
I believe the 3/4 & 1 ton had torque tube off the transmission & open drive shaft from the carrier brg. on back.
If the pinion brg has play in it the seal will not hold.
George
You are correct, George. I just checked the service manual.
My dad had a 51 GMC 3/4 ton as his shop truck and I remember it needing the rear end rebuilt, I vaguely recall the guy at the repair shop (fondly known as "Greasy Bob" wink ) using dad's pipe dope to check the gear pattern and turning the driveshaft at the end of the torque tube. Maybe GMC 3/4 ton's use the torque tube rear axle. ohwell I'm sure somebody with a GMC here at Stovebolt could confirm or deny that.
Kevin
1951 Chevy 3100 work truck
Photos
