Why does Dynacorn break its AD bodies into 1947-1950 and 1952-1955?
That doesn't seem to make any sense. And what about 1951?
No one makes doors for ‘51s. Door latches changed in 52 also strikers.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
