2 members (KCMongo, baldeagle),
33
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,005 Posts1,055,254 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | A large discharge in the "key off" position is caused by stuck cutout relay points. Disconnect a battery cable RIGHT NOW, or the battery will discharge itself through the generator and burn both units out. Your "new" regulator is defective and needs to be replaced. A 1/2 volt drop between the regulator BAT terminal and the battery indicates there's a dirty connection somewhere- - - - -at an ammeter connection, or possibly at the battery cable connection at the starter. You should be getting approximately 7.5 volts, measured at the battery posts (not the cable terminals) with the engine running at a fast idle with a fully charged battery if the regulator is adjusted properly. Jerry
