| | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | I find it a little weird that to two ends are .003? Even a tiny bit of uneven wear on the crankshaft journal or the bearing will produce different clearance depending on where you measure. Since a strand of hair is around .0015" in diameter, it doesn't take much wear or out of round to produce some oddball clearance measurements. Jerry
