8 members (kurbside bolter, tclederman, FAST55, Hotrod Lincoln, KEVINSKI, 1955 1 Series, Charles in CA, Otto Skorzeny),
153
2
Mod | | | Forums66 Topics128,267 Posts1,058,373 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 81 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 81 | The pedal set on the 1/2 ton trucks bolt to the bellhousing and the transmission. The big bolts of that era had the pedals bolted only to the bellhousing and used a remote frame mounted brake master cylinder. I've seen people use the original setup just bolted to the bellhousing, but I would fabricate a bracket to support the back end of the pedal mount to the new transmission.
Steve
Steve
1946 1/2 ton
