8 members (kurbside bolter, tclederman, FAST55, Hotrod Lincoln, KEVINSKI, 1955 1 Series, Charles in CA, Otto Skorzeny), 157 guests, and 2 robots.
Topics128,267
Posts1,058,373
Members48,485
I’m gathering parts to do a T-5 5spd trans conversion on my stock 1946 truck. It just struck me, what does everyone do about their master cylinder and pedals that bolt to the old original transmission? I was planning on keeping my original brakes, (for now), and keeping the pedal configuration…..but they bolt to the side of the original transmission. What is everyone doing?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
Don't those items bolt to the bellhousing? You can bolt the the T-5 to your original bellhousing. problem solved. (I think)
[img]https://www.stovebolt.com/ubbthread...2AA1186-BF37-4D29-902E-6350DA6F6983.jpeg[/img]No, they bolt to the side of the transmission.
The pedal set on the 1/2 ton trucks bolt to the bellhousing and the transmission. The big bolts of that era had the pedals bolted only to the bellhousing and used a remote frame mounted brake master cylinder. I've seen people use the original setup just bolted to the bellhousing, but I would fabricate a bracket to support the back end of the pedal mount to the new transmission.
Steve
Steve
1946 1/2 ton
I also made the T5 conversion and made a support mount to one of the tail housing bolts.
Joe
just retired and finally making headway on my project truck. 1940 GMC AC152.
