That is not a dum question at all, I just assumed it was correct. I have to pull the cover again and will check it. My next question is will a 35 timing cover and damper fit so I can put a seal in it? I am trying not to pull the oil pan as it’s been a pain in the neck getting the seals correct on this thing and have had it off twice already, if I have to drop it and check bearing clearance with some gage material I will do what needs to be done. Can you remind me of the angle the tube should be at again as I do not have a manual yet.
1933 207 stovebolt shoved into a Chevy 1/2 ton with all the 29-32 left overs. (Woody) - all original, originally old!
Courage = Being scared to death, then going to do the task anyways!
