| | | Forums66 Topics128,260 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | https://www.ebay.com/itm/282715400118https://realgaskets.com/product/valve-cover-gasket-44/Follow the instruction sheet. Valve covers are usually overtightened and warped. I restraighten them flat and use a new (fresh, not NOS) cork gasket with no sealant. Cork naturally weeps a small amount of oil but this is normal.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
