| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You should be able to use your '48 bell housing to solve the rear mount problem.
Hopefully the '59 engine will have the lip for the front motor mount but probably won't have the holes for it. Take measurements from your old engine and lay out the holes on the lip. Drill them then square the holes with a file.
You'll also have to shorten the shaft on the 261 water pump and get a shorter pulley. There's plenty already posted about that so do a search.
One more thing. If you want to use your 6V starter, you'll have to use the '48 flywheel. | | |
